2001 Chevy Astro engine not starting
BIG_JOHN
  • 2001 CHEVROLET ASTRO
  • 6 CYL
  • 188,000 MILES
Ive had a mechanic look at my van and he said it was way out of time. So I had him replace the timing gears and chain. And I drove it home. But now it will not start at all. After discussing the problem to the mechanic again now hes saying its the fuel pump, but I can hear the fuel pump running when I turn the key. Is there anything I can do myself to try to problem solve my issues?
i once had a ford that had a switch for the fuel pump. But even then it wouldnt make a sound when I turned the key on it till I reset the switch. Is this van equipted with such a switch?I dont have an owners manuel I bought it used
Tuesday, June 15th, 2010 AT 12:21 PM
INTERNETMECHANIC
  • 700 POSTS
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
The above link may have your owners manual, it's free. Type in year--make--model. There is another web site that has GM owners manuals online. gmownercenter.yahoo.com, something like that.
I'd use a fuel pressure gage before I suspected the pump. Some of the national brand auto stores used to loan out a fuel pressure gage. There is no fuel pump shut-off switch, if that is what your talking about? If you have the 4.3L engine, fuel pressure is 60--66 psi.
Tuesday, June 15th, 2010 AT 1:27 PM
BIG_JOHN
Thank you for the information. The fuel pressure was too low
now the engine is starting, but when I accelerate it dies.
Ive replaced the plugs, wires, cap, rotor, coil
might you have any suggestions on the cause of this new problem
Monday, June 28th, 2010 AT 12:52 AM
INTERNETMECHANIC
  • 700 POSTS
Low fuel pressure might cause that. If you have the spider fuel system, the fuel poippets may need cleaning, if it is a fuel issue?
Monday, June 28th, 2010 AT 11:49 AM
