How do I check the heater/air conditioner switch which controls what position the air flow doors is in?
May 13, 2010 at 9:31 AM
✓Experienced Mechanic
Basically you supply vacuum to the input. From there, you switch it and the direction of the vacuum should change. What is happening to the car making you think the switch is bad?
