2002 Chevy Astro No Air From Vents
MYLE74
My 2002 Astro van's air conditioner is blower cold air but nothing is coming out of the vents. Also, the control switch will only shut it on or off but won't change from Ac to vent to floor, etc... I can feel cold air out of the passengers floor vent and a little from the drivers side vent.
I wonder if the it is the switch or the shudder itself is stuck.
Jul 20, 2007 at 7:02 AM
AQUARIAN1000
the handle on the switch is broken-5 bucks for used one at wreckers
May 26, 2012 at 4:45 PM
  • 110,251 POSTS
Also, check to make sure there are no vacuum leaks under the dash. The vent doors are actuated with vacuum
Jun 25, 2012 at 7:49 PM
DJCL
  • 767 POSTS
Under the hood check to see if there are broken vacuum lines around the pass side. Very co min fore them to brake and leak.
Jun 26, 2012 at 12:20 AM
Suggested Repair
Replace the broken mode-control switch handle, and inspect for vacuum leaks under the dash and broken vacuum lines on the passenger side under the hood. The vent doors are vacuum-actuated, so a leak can prevent mode changes even when the system is cold.
Conversation Summary
The owner of a 2002 Chevrolet Astro said the air conditioner produced cold air, but little or none came from the vents and the control would only turn the system on or off. Cold air was felt mainly at the passenger floor vent and slightly at the driver-side vent. A reply noted that the switch handle was broken and a used replacement was inexpensive. Experts advised checking for vacuum leaks under the dash and broken vacuum lines on the passenger side under the hood because the vent doors are vacuum-operated.
