1997 Chevy Astro Blower Only on High
BDEIBERT
I have a 1997 Chevy Astro van with 92000 miles. The A/C blower will only blow in the high setting. All dash blowing positions work fine, i have already been through the vacuum line problem. What can I do to fix the blower speed selector?
Jul 5, 2007 at 9:00 AM
BOOTDOG
  • 665 POSTS
replace the resistor. also it wouldn't hurt to replace the blower motor too. i've ran into a situation where on 97 astro's, the blower motor will short out the resistor. replace both. kill 2 birds with 1 stone. you'll have less headaches later.
Jul 5, 2007 at 12:31 PM
Suggested Repair
Replace the blower motor resistor and the blower motor together. On 1997 Astros, a failing blower motor can short the resistor, so replacing both reduces the chance of a repeat failure.
Conversation Summary
The owner of a 1997 Chevy Astro with 92,000 miles reports the A/C blower works only on high, while all dash airflow positions work. Vacuum lines were already checked. The expert recommends replacing the blower resistor and also the blower motor, because a failing motor can short the resistor on these vans.
