1998 Chevy Astro codes
FREDDIE YSLAS
Computer problem
1998 Chevy Astro 6 cyl Automatic 8.000 miles
will your car run bad if you do not clear your codes
Nov 3, 2008 at 7:56 AM
DAVE H
  • 13,383 POSTS
the car should run fine if you have repaired the actual fault ?? clear the codes .. test drive the vehicle .. and see which codes re-occur ??
Nov 9, 2008 at 1:25 AM
DMEYER
how do you erase the codes? I have a 95
Mar 6, 2009 at 9:59 AM
DAVE H
  • 13,383 POSTS
take the vehicle to a good autoparts store (autozone etc.) and have them clear the codes .. ask them what the codes are and write them down ...incase the light comes on again so you can see if it is the same codes ..(most good autostores do this free) or you could just disconnect the battery for 5 minutes ..you will need the radio code if you do this and will have to let the PCM(computer) do a relearn drive cycle afterwards .. drive in stop and go traffic and highway for about 15/20 minutes standard driving !!
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_22.png
Mar 6, 2009 at 10:21 AM
