runs rough at idle with a noticeable vibration?
1994 CHEVROLET ASTRO
150 MILES • 6 CYL • 2WD • AUTOMATIC
CHIMAERA
My astro runs rough at idle with a noticeable vibration and it has now failed emissions. I have cleaned the EGR valve, the CPI module was replaced a few years ago as was the plugs, wires, and distributor cap. There was a rattling sound in th cat prior to this issue that has gone away. I have had the injectors cleaned by the shop. He did say my wires were looking tired again. I'm going to try plugs and wires, but the severity of the vibration and emissions makes me skeptical.
Dec 15, 2007 at 11:25 AM
  • CERTIFIED EXPERT
Get the exhaust system check for an excessive backpressure, idle air contol valve, and throttle position sensor. Replace tune-up parts-
Dec 15, 2007 at 11:50 AM
  • CERTIFIED EXPERT
  • 53,877 POSTS
Yes, but I would check the compression before wasting your time. Here are two guides that will help us see what's going on and if the gnien is worth fixing.
and
Please go over these guides and get back to us.
Oct 17, 2024 at 5:37 PM
