running bad
DADDYOFZAKK
i have a 1991 chevy 1500 350 engine 189,000 miles it had a miss to it when the motor warms up and when you come to a stop it runs real rough.somtimes it runs great all day then sometimes it's real bad i changed the coil,plugs,cap,button.wires.did not help at all it has hardley no power and now its starting to smell like raw fuel.i done a compression test i had 5,at 180,2,at,155,and 1,at,135 i can not figure it out because of the run good somtimes run bad other times so please help.....thank you in advance for your time
Oct 22, 2007 at 11:28 AM
  • 75,988 POSTS
Your compressions don't look right-However you can try cleaning out idle air control valve and the EGR.
Also check what's happening with the fuel system by doing a fuel pressure test with gauge.
There's a lot that can cause your problem
Intermittent problems can be the worst nightmare to deal with.
Oct 22, 2007 at 12:27 PM
