1996 Chevy Astro Spark
FORESTVIEW
  • 1996 CHEVROLET ASTRO
  • 6 CYL
  • 4WD
  • 210,000 MILES
Ok, we replaced rotor, cap, and coil, we get spark at the coil and the rotor does spin when cranking the engine, but still no spark at the plugs.
It does not start when it gets wet and it has happened before so that is why we replaced everything from wires to coil etc. All it does is turn over. Would timing make no spark at the plugs?
We just keep pounding our head on the wall.
Monday, December 28th, 2009 AT 2:12 PM
OSCAR442CUTLASS
Hello check all you sensors especially Camshaft position sensor and crank position sensor if one of them is bad it will cause a no spark situation. Also scanning it for trouble codes either by the way the rapair manual tells you to do it or with a hand held scanner like the autoxray.(If available)
Monday, December 28th, 2009 AT 2:21 PM
JDL
  • 16,098 POSTS
Hi, myself and docfixit both have tried to talk to you, if you'll stay on the same post it will help. Thanks
Monday, December 28th, 2009 AT 2:22 PM
FORESTVIEW
What is a camshaft sensor or crank position sensor? Is this something we can replace without taking it to a repair shop?
Monday, December 28th, 2009 AT 2:41 PM
