1996 Chevy Astro Van will turn over but will not start
KRISTINA MANNING
  • 1996 CHEVROLET ASTRO
  • V12
  • AWD
  • 199,999 MILES
I want to know what could be wrong with my 96 chevy astro I was driving up the street and the van just died. It will turn over but it will not start. I had my fuel pump check that was not the problem. I was told it's either the time changing or a censor. Is this a common problem with these model vans?
Wednesday, April 14th, 2010 AT 8:22 AM
Do below to determine whether it's fuel or spark problem:
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Wednesday, April 14th, 2010 AT 3:35 PM
