If you have the cmfi fuel system, there are bulletins about cleaning the fuel poppets.
I know you said the pump runs, but, I can't rule out a fuel pressure issue. Can you check fuel pressure? It does sound like a fuel issue.
If your still obd 1, 12 pin data link connector, check for codes.
SPONSORED LINKS
Tuesday, October 28th, 2008 AT 10:05 AM
