Electrical problem
1994 Chevy Astro 6 cyl Two Wheel Drive Automatic
I do not hear the fuel pump load, my starter does not turn. the volt meter in the van shows low 10 volts.
a hand held meter shows 13V 12V when I have everything turned on. horn is loud radio plays well again all components turned on battery held at 12V
Charged battery anyway, side mount terminals so they are not corroded. I tried the neutral switch and re set as the Chilton book said.
van does not start in park or neutral. the back up light illuminates.
Aug 23, 2010 at 7:16 PM
