Hi, I purchased this vehicle from an auction therefore have no knowledge of past performance. The problems is that it will not start or run with fuel system. It will run on starting fluid however. I have checked for spark, that is good. I have replaced the fuel filter, and I have approx 60lbs pressure at the rail, that stays for a couple of minutes after the key is off. I am assuming that this is the fuel pressure regulator, as everything I have read points to that.
Do you have any other suggestions that I might look at once the plenum is off?
Thanks,
Jerry
SPONSORED LINKS
Tuesday, June 16th, 2009 AT 2:28 PM
