1988 Chevy Astro Does this sound like a blown head gasket?
1988 CHEVROLET ASTRO
145,000 MILES • 6 CYL • 2WD • AUTOMATIC
ORIONKC
I was driving homefrom work and I felt a litttle shutter in the engine when I got off the highway, felt like it was kindof misfiring(hesitating a bit) I didnt pay much mind to it and finished home(1/4 mle)
Once at home I let it sit for aout 10 minutes and headed back out and it was still runnig funny. A bout a mile into it I noticed a light smoke(steam) coming from the back of the van. a few minutes later it was runnig very rough and smoking(steaming) badly. At a light I would be smoking heavily and when it was time to proceed, when I hit the gas I would smoke out the intersection. I checked the oiland it looks fine, the coolant wasa bit low and the exhaust smells funny.
Does this sound like a head gasket? I have very limited funds as I just moved to a new state. I can do th e change myself but want to make sure this is the possible problem. I have just got a new job and need to make sure this is the root problem. Need to fix ad cant afford to mess around and keep buying parts.
If I could I would donate but this time I wont be able to. Sorry.
Thanks in advance!
May 31, 2009 at 9:21 AM
  • 110,244 POSTS
If the smoke is white coming from the exhaust, it sounds like a headgasket or intake gasket. Check the engine compression. A bad headgasket will give a lower reading in the affected cylender. Intake gasket will have no affect on compression.
Let me know what you find.
Jun 1, 2009 at 2:07 AM
