Check engine light?
RENEE L
  • ADMIN
  • 1,260 POSTS
Hi
If you decide you would like to conduct the scan yourself here is a link to an article that features written step by step instructions and pictures explaining how to do the scan yourself, also I have included a link to our YouTube channel with a how to video on code scanning. Most scanners are inexpensive to purchase, you can purchase one online from sites like Amazon.com
https://youtu.be/YV3TRZwer8k
Once you have the codes please get back to us so that we can further assist you. We are always happy to help.
Thank you for visiting 2CarPros.com.
Kindest regards,
Renee
Admin
Wednesday, January 6th, 2021 AT 12:29 PM (Merged)
GPLAYEZ
  • 2005 FORD EXPLORER
  • V8
  • AWD
  • 36,000 MILES
Service engine light came on. No other problems, fuel gauge works properly. Did the 3 cold starts as
noted in the owners manual. Light stayed on.
Dealer checked code and says it came back P0463. One possible cause is high sulfur content in fuel
according to their research.
Dealer wants to drop tank and replace fuel pump. Since everything else is fine I question if the fuel pump replacement is necessary. Would it hurt anything to
just keep on driving as is? Am I likely to find myself stranded somewhere? If sulfur is problem won't the new pump be effected as well?
  • 109,885 POSTS
I see no reason to replace the fuel pump. If there is a high sulfer content in the fuel (which I never heard of), a different pump isn't going to change that.
P0463 Fuel Level Sensor Circuit High Input
I feel you have an electrical issue and not a problem with high sulfer fuel. If the fuel level sensor circuit it getting more power than it should, how can that be the issue?
GPLAYEZ
First of all thank you. The reason for "sulfur" answer
came from "ALLDATA". The dealer gave me a print out from them which suggests that the sulfur content causes an open or high resistance on the fuel sender card.
  • 109,885 POSTS
Have they taken care of it for you?
RAMZ
  • 80,000 MILES
Light of service engine soon code appeared in my car, how to repair it?
DRCRANKNWRENCH
  • 3,380 POSTS
First you need to have the trouble codes pulled. Any Advance Auto or Auto Zone will do this for free. They will give you a set of codes that translate to problems with your car. They can clear the codes for you, but until the problems are resolved, the trouble light on the dash will return.
