After changing out the key ignition, the truck will not start?
159,000 MILES • V6 • 4WD • AUTOMATIC
BIGBAMBOOM
I changed out the key ignition myself. The engine started and ran perfectly. I can hear the gas pump turn on and see the gas being delivered via the carb. To check for spark I pulled a plug wire off a plug. Inserted a 2–3-inch Phillips driver bit and held it close to an engine bolt and I clearly had spark. The engine ran great before this, so the problem must be in the steering column. Thank you for all that you do. Dave
Nov 21, 2023 at 3:09 PM
  • 110,248 POSTS
If you presently have fuel and spark, the engine should run. By chance, does the engine fire and then stall when you try starting it?
Also, here is a link that explains how to retrieve diagnostic trouble codes on this vehicle. You don't need a scan tool. All you need is either a short jumper wire or even a paper clip.
Follow the directions in this link and let me know what you find:
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Next, I don't know if the vehicle has one, but is there a security light or anti-theft light staying on or flashing?
Nov 22, 2023 at 1:35 PM
