Changing a four-barrel carburetor to a two-barrel carburetor?
300,000 MILES • V8 • 2WD • AUTOMATIC
JCWOLF
Replacing a 4-barrel carburetor with a 2-barrel carburetor.
Jul 12, 2022 at 9:48 AM
  • 110,248 POSTS
I'm not sure what you are asking. If you plan to do this, you will likely need to replace the intake manifold, throttle linkage, kick down linkage, and fuel supply routing.
Is that what you need? If not, let me know. Also, let me know which engine this has. I suspect it's a 351 ci, but I know a 302 and 460 were offered as well. If it had a 4bbl, it wouldn't be the 300ci.
Take care and let me know.
Jul 12, 2022 at 3:06 PM
JCWOLF
The motor is a 460. I have already been able to attach the carburetor to the motor now I just need to be able to hook everything up to it.
Jul 13, 2022 at 6:28 AM
