Car will not start dead battery
56,784 MILES • 1.4L • MANUAL
CYMROMEL
In last two months four times I've had a dead battery. so I put on charge but for a reason the trailer light is flashing and wont go off, but when I turn ignition try see if battery charge then trailer light stops flashing but only thing that comes on the dash is sbs but still car wouldn't start but clicking noise. so turn ignition off and trailer light back on flashing on it own and can't switch it off. Appreciate it so much as I have no idea and don't want buy a new alternator or battery without idea if it something else. thanks
Apr 7, 2019 at 8:05 AM
SEVAG P
  • 405 POSTS
hello thank for using CarPros.
it seems you have battery drain after turning off the engine. as a first step recharge the battery.check our guide:
https://www.2carpros.com/articles/how-to-charge-your-car-battery
Aafter charging perform battery load test to check the condition of the battery.
Perform battery drain test overnight.
https://www.2carpros.com/articles/car-battery-dead-overnight
Our guide battery replacement:
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Let us know if you need more help.
Apr 8, 2019 at 6:17 AM
CYMROMEL
Will do try that. thank you so much.
Apr 8, 2019 at 8:08 PM
SEVAG P
  • 405 POSTS
You are welcome. waiting your reply.
Apr 9, 2019 at 12:41 AM
