Car wont stay running after it's started
ELR67
  • 2001 FORD FOCUS
  • 222,000 MILES
It started out with the car not pumping fuel through the fuel rail so I replaced the fuel pump, that didn't work. I was able to get two codes p1237 and p1132, I replaced the fuel pump driver module and I checked/cleaned the fuel fuelinjectors, that still didn't work. The car has a smooth start, runs a few srconds then cuts off. Any Ideas?
Friday, September 20th, 2013 AT 9:02 PM
HMAC300
  • 48,601 POSTS
Try resetting your anti theft system first 1237 is either a faulty, fuel pump relay inertia switch, pcm or fuel pump driver module. Try jumping inertia switch see if it will runok then. 1137is fuel injector circuitry/ O2 sensor harness problem wiring problem or pcm. I think the if theo one if fixed then it may take care of the other.
Saturday, September 21st, 2013 AT 6:00 AM
