Car will not start in damp or cold weather
250,000 MILES • V8 • 2WD • AUTOMATIC
MONIKA YOST
When starting engine during damp and/or cold conditions, the electronic fuel control system does not provide spark. Have exchanged it numerous times. When you turn the ignition on it will give one spark. You may get a spark every three or four attempts. But as soon as you turn the key to start the engine, there is no spark. Other than bringing the electronic fuel control system and placing it near a heat source makes it work again. Is there another sensor or component that may be causing this issue? Any suggestions how to fix this issue once and for all?
Dec 7, 2017 at 1:13 PM
CARADIODOC
  • 34,413 POSTS
The most common suspect is the pickup coil inside the distributor, but there are two versions. One system uses just one pickup coil. There will be a single connector with two terminals at the end of about six inches of wire. The other system uses two of those pickup coils, one for cranking and one for running after the engine starts. That distributor will have two 2-terminal connectors. Those coils are identical, but they are positioned slightly differently so the "crank" coil retards ignition timing a little so the engine will start easier.
When you have two pickup coils, switching between them is done with a relay. That relay is another good suspect. A quick test to check for a defective pickup coil is to just unplug both of them, then switch the connections. You will be cranking the engine on the "run" pickup coil, which has more timing advance built in, so the engine might crank with slightly more difficulty, but if the "crank" coil is bad, the engine will run on that "run" coil until you release the ignition switch from the "crank" position, then it will stall.
If you have the small five-terminal ignition module, (only uses four of them), on the inner fender, the housing is the ground connection. Be sure it is mounted solidly to the body and those bolt holes are not rusty.
Dec 8, 2017 at 4:51 AM
