The code is related to the throttle actuator control (position) sensor. I do not see why that would make a difference by having the vehicle jump started.
When the vehicle is not jumped, does it crank normally or does the starter fail to turn the engine? Have you checked to make sure the battery terminals are clean and tight as well as the battery being good?
If you have not checked the battery or terminals, follow these links which discuss battery load testing and terminals.
You will need to use a volt meter. Here are directions on how one is used:
I am asking that you start with these tests because something as simple as a weak battery connection can cause this. It can also have an adverse effect on electrical components once the car is running (after being jump started).
Do this and let me know what you find. If you have other questions, let me know.
Oct 20, 2018 at 11:19 AM
