Will not start, I was unaware that the car was overheating?
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
KZENTZ
I believe that the thermostat stuck, and I was unaware that the car was overheating until it stalled, and it would not restart.
Nov 26, 2022 at 4:40 AM
  • 110,248 POSTS
How badly did the engine overheat? Was the gauge fully in the red area? If it was, the first thing I need you to do is record the engine cranking and upload it for me to hear. There is a chance you warped the cylinder head and have lost compression. I should be able to tell by listening to it.
If you can't do that, try this and let me know what happens. See if it starts using starting fluid. If it does and then stalls, we know there is fuel related issue. If there is no change, check to see if there is spark to the plugs.
Here is a link that explains how that is done:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
If you have spark and starting fluid makes no difference, chances are we lost engine compression. If this is suspected, you will need to perform a compression test.
You will need a compression tester, but most parts stores will lend one to you free of charge. Here is a link explaining how it is done.
Nov 26, 2022 at 2:29 PM
