Will not start?
170,000 MILES • 1.5L • 2WD • AUTOMATIC
SASIKUMAR82
I changed battery.
I changed the ignition coil.
I changed the alternator.
I changed the sensor.
But won't start.
Oct 12, 2022 at 3:00 PM
BORIS K
  • 836 POSTS
First of all, does the engine crank over but does not start or does the engine not crank?
Is the engine light on?
If so, next carry out a CAN scan to check for any relevant code.
How to:
Post the fault codes on our site for further evaluation.
A good video:
https://youtu.be/dCjmRL3p4Cs
and
Hope this helps.
Cheers, Boris
Oct 13, 2022 at 1:22 AM
SASIKUMAR82
Engine cranks but no start. The engine light sometimes has and sometimes no.
Oct 13, 2022 at 1:32 AM
BORIS K
  • 836 POSTS
As mentioned before, if the engine light is on then there will be fault codes stored.
I would suggest to first conducting a CAN scan using a suitable diagnostic tool.
Once you have retrieved the fault codes, please post them here so that we can evaluate them and advise you accordingly.
This is usually the quickest way to diagnose a non-starting situation.
How to carry out a CAN scan:
Cheers, Boris
Oct 13, 2022 at 5:59 PM
