Crank no start issue?
23,000 MILES • 4 CYL • 2WD • AUTOMATIC
JANALANE
My car will turn over, but it will not start even after I got a jump. It had been in the below zeros all week so I'm hoping it's just the battery. What do you think?
Jan 2, 2023 at 7:46 AM
  • 110,248 POSTS
Does the starter engage with the engine and turn it and then the engine just doesn't start? Also, is the temperature outside still below 0? I ask because yes, the cold may have affected the battery, but if it is cranking with a jump, it should still start. It makes me think you may have fuel line freeze up which isn't common, but it can happen.
Do me a favor. First, make sure the battery terminals on your vehicle are clean and tight.
Next, if the engine cranks okay with your battery, great. If it doesn't, I would recharge it.
After the battery is good, then I want you to see if the engine will start with starting fluid. If it starts and then stalls, we know there is a fuel-related issue. If there is no change, then I need you to check for spark at the spark plugs.
Here is a link that explains how to check:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Try this and let me know the results. Also, if you need to jump-start it, make sure not to create sparks when using the starting fluid.
Take care and I'll watch for your reply.
Jan 2, 2023 at 12:54 PM
