Car will not start?
87 MILES • 1.8L • 2WD • AUTOMATIC
RAKEL PATRICIA
The car stops reading fuel and now won't start.
After trying to fix buzzing in stereo, engine light comes on and battery drains but went to read (odb) and erase faults and no light comes back. It makes a sound, and something spins in engine but not starting.
Nov 30, 2023 at 8:49 AM
  • 110,248 POSTS
Is it possible for you to record it cranking and upload it for me to hear? Also, can you tell if the fuel pump is priming when you first turn the key to the on position?
Also, in most cases, a crank no-start condition is caused by either a fuel-related issue or an ignition-related issue.
Here is what I need you to do. See if the engine will start if you use starting fluid. If it does and then stalls, we will know it is a fuel-related issue. If there is no change, I need you to check if there is spark to the spark plugs.
Here is a link that explains how to check for spark:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Nov 30, 2023 at 11:54 AM
