Sometimes the car will not turn on
150,000 MILES
AMOS VIVANCOS LEON
I have the car on Neutral or Parking. Then I turn the key to start the car and all the lights turn on, but the car does not start. there are no sounds. As if the battery was dead, but the battery is fine because the lights turn on and after turning the key on and off a few times, it starts. If it has started and I turn the car off and try again, I have the same problem. its like a fifty percent chance that the car is going to turn on. I think there is something wrong with the starter.
Mar 12, 2017 at 5:54 AM
HMAC300
  • 48,601 POSTS
this may be a security issue or one of the items in the starting system. Check to see if power going to starter with either a test light or volt meter when you try to start you will need help with this. It could be the starter, but I kind of doubt it. See link if you need further help have it checked by a mechanic.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Mar 13, 2017 at 12:29 AM
