Car will not start
162,000 MILES • 4 CYL • FWD • MANUAL
GODSLADY49
My car is the ZX2 model. I have replaced the spark plugs, distributor cap, cam shaft position sensor and had the timing professionally set by hand and my fuel pump has been checked and is working good. my car was running rough in first, second and third gears evening out just before shifting into fourth (it ran rough for about a month). I parked it at a friend's house and when I went to go home my car would crank but not turn over. I am running out of ideas and patience as it has been four months since I had to get it towed home. I need some possible ideas as to what has happened and what can I do to get it running again. It now seems to drain my battery when nothing is on.
Oct 3, 2017 at 1:19 AM
VAUN POFFENBARGER
Have you checked the spark plug wires to see if they all have a spark, I am actually working on an Escort right now too, but the ignition coil was bad. Mine still will not start, but it was one more thing it needed.
Oct 3, 2017 at 5:27 AM
  • 55,746 POSTS
Lets start by checking for ignition spark that way we can determine if it is the crankshaft angle sensor or something like that.
Here is a guide top help us get started:
Here is a general guide that can help as well:
Please let us know what you find.
Cheers, Ken
Oct 4, 2017 at 7:06 AM
GODSLADY49
Well, we have replaced everything now. My car still does not start and the only thing remaining is the code reader. Will let you know what happens.
Nov 4, 2017 at 7:59 AM
  • 55,746 POSTS
Does the engine sound normal when it is cranking? I am wondering if it has compression?
and
and
Cheers, Ken
Nov 5, 2017 at 5:16 AM
