HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Escort
Engine
Symptoms
Not Running
2000 Ford Escort car not wanting to start at times
DAVIDBELLA
MEMBER
2000 FORD ESCORT
4 CYL
2WD
AUTOMATIC
90,000 MILES
My car at times starts fine then at no particular time when u turn the key it wont even turn over nothing
Friday, April 18th, 2008 AT 8:58 PM
BMRFIXIT
MECHANIC
Check battery terminals and clean + tighten
try to start in neutral (if OK in N will not start in P neutral safety switch need to be checked )
check starter solenoid and replace if needed
check starter wiring and or replace
Sunday, April 20th, 2008 AT 8:06 AM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
2000 Ford Escort No Start, Mechanics Baffled!!
I've Recently Posted About A No Start Problem. Current Situation Is No Start. There Are No Noises, Clicks Or Anything When Trying To Turn...
Asked by
aron42486
1 ANSWER
2000
FORD ESCORT
VIDEO
Car Cranking but Not Starting? Try This
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
2000 Ford Escort Car Won't Start
Have Cleaned And Tested Starter - It Works Fine. Replaced Battery, Cleaned Plugs. Starter Engages, Engine Spins But Won't Start.
Asked by
jazzergal503
2000
FORD ESCORT
I Have A 2000 Ford Escort Zx2 And Has Spark And...
I Checked The Spark Both Ways And I Have Spark And The Engine Turns Over But Wont Start. Also Changed The Fuel Pump Which Was The First...
Asked by
ga1089
2000
FORD ESCORT
2000 Ford Escort Won't Start
I Drove Through Snow On Wednesday And On Friday The Car Would Not Start. It Had Begun Ot "growl" In Forst And Second Gear After Wednesday...
Asked by
Jessilyn29
1 ANSWER
2000
FORD ESCORT
2000 Ford Escort No Start (con't)
My Previous Post Was: My Car Will Not Start. With The Key In The On Position (before Trying To Start), No Electrical Components Will Come...
Asked by
aron42486
2000
FORD ESCORT
VIEW MORE
How to fix an engine that wont start
Crankshaft Sensor Symptoms
