Car stalls
DAVE H
  • 13,384 POSTS
Have the vehicles's PCM read for fault codes and get back to us with the codes. Most good autoparts stores (autozone etc.) Do this for free.
Monday, February 11th, 2019 AT 6:59 PM (Merged)
BINGO
  • 2000 FORD FOCUS
  • 4 CYL
  • FWD
  • 104,000 MILES
Car lost power after going up a hill. Slowly stalled out. Battery light, Alt light, and oil light all came on. I waited awhile with car shut off, to let it cool down & started it up and I made it home. But this has never happened before. So what do you think happened?
  • 110,053 POSTS
A few things could cause this. First, the fuel pump may be going bad. I recommend having fuel pressure checked. If you need directions, let me know. Next, the catalytic converter could be starting to plug. If this happens again, check to see if it is red hot. If it is, replace it.
Let me know what you find.
2CP-ARCHIVES
  • 4,540 POSTS
  • 2000 FORD FOCUS
  • 12,000 MILES
Knocking sound and won't stay running cuts right off when I start
DRCRANKNWRENCH
  • 3,380 POSTS
Sounds like internal motor damage. Have it tested for engine compression. You might need an engine rebuild.
INVADERZIMMERMAN
  • 7 POSTS
  • 2000 FORD FOCUS
  • 168,000 MILES
My car shuts off when it idles. But just for a second. Then it starts back up again. What could cause this?
  • 110,053 POSTS
Check for vacuum leaks and check the idle air control valve. (IAC)
LINTON
  • 2000 FORD FOCUS
Engine Performance problem
2000 Ford Focus Two Wheel Drive Manual 77000 miles
The car drives fine apart from it only ticks over at about 700 rpm, when I loose my foot off the throttle the engine cuts out and shows the warning light, this does not happen if I coast on the clutch. I have been told it is the throttle sensor position?
RENAUDTN
  • 636 POSTS
Could be the TPS indeed. Back probe the wires at the sensor, One is your ground (around 0V), another one is your hot wire (about 5V), and the last one is your signal wire. When you open the throttle, the voltage at the signal wire should go up steadily until 5V (fully open). When you close the throttle, the voltage should drop back down steadily. If it doesn't go up and down steadily, but rather jump from say 1V to 4 V all of a sudden, that indicates a bad TPS.
You can also disconnect your TPS and put a ohmmeter across your signal and supply wires. As you manually open and close the throttle, the resistance should increase and drop. If you have erratic readings, the sensor is bad.
P.S: I would also check the fuel pressure to make sure there's nothing wrong with that.
MOSCHOPS
  • 2000 FORD FOCUS
  • 1.4L
  • 4 CYL
  • FWD
  • 117,564 MILES
Engine shuts off when I approach junctions or roundabouts, idles at about 750 rpm. I have taken idling valve off and cleaned with wd40, problem disappeared but has come back
  • 110,053 POSTS
Either you have a vacuum leak or the IAC is bad. Keep in mind, WD40 is a lubricant and not a cleaner.
