2001 Ford Focus Car will start but not stay running
HHICKMAN
  • 2001 FORD FOCUS
Engine problem
2001 Ford Focus 6 cyl Wheel Drive Type unknown Automatic 96000 miles
I need help with a strange problem. The problem usually happens when it is warm outside. I will drive the car for a while (at least 30 minutes) and then stop somewhere. When I come back out, the car will start but not keep running without pressing on the gas. As long as you keep the gas pressed a little, you can go. As soon as you stop or coast, it dies. Then I let it rest for a couple of hours and it works fine again. I already replaced the fuel filter and pump. Any input would be appreciated. Thank you.
Holly
Wednesday, February 20th, 2008 AT 8:43 AM
Do you have a check engine light or has flashed?
Check the idle speed control motor/valve and throttle position sensor and also the EGR
Saturday, February 23rd, 2008 AT 5:37 AM
HHICKMAN
Nothing comes on before the car dies, but if I let it die there are a couple of lights that come on. How do I know which ones they are?
Monday, February 25th, 2008 AT 3:53 PM
When you turn key to run-the check engine light should come On.
Monday, February 25th, 2008 AT 5:16 PM
