The car hesitates on acceleration. It doesn't respond to the accelerator position. The position sensor has been changed. IAC changed. Ignition control module changed. MAF sensor changed. Coils and plug wires changed. New plugs. All the vacuum system has bees gone over and any check valves and old hoses changed. If the accelerator is pressed hard the car will downshift and accelerate fast. The engine fault code is ignition control module. Don't know what else there is short of the
cpu.
SPONSORED LINKS
Wednesday, September 2nd, 2015 AT 6:11 AM
