Pull the code/s from the computer by jumping A to B in the DLC this is your starting point finding out what's really going on
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
SPONSORED LINKS
Wednesday, July 22nd, 2009 AT 7:41 PM
