Car stalls when engaging clutch
244,500 MILES
REBECCA SWENSON
I just installed a new battery and now every time I engage the clutch the car stalls out. The car does stay on when I first start it. It's only while I'm driving and go to shift that it stalls out. What could be the problem? Please help
Apr 12, 2019 at 1:52 AM
CARADIODOC
  • 34,412 POSTS
Hope you're sitting down; this is going to be real involved!
Go out and drive the car, then, when the engine is warmed up, leave it in gear like normal, and from highway speed, coast for at least seven seconds without touching the pedals.
The glaring clue is the battery was disconnected. Thank you for including that. The Engine Computer lost its memory. Most of the learned data will be relearned as soon as you start driving, except for "minimum throttle". The computer needs to see a specific set of conditions met while coasting, that tells it your foot is off the accelerator pedal. It relearns the signal voltage from the throttle position sensor, and from then on, it knows it must be in control of idle speed any time it sees that same voltage. Until that is relearned, the engine might not start and run unless you hold the accelerator pedal down 1/4", you won't get the nice idle flare-up to 1500 rpm at start-up, and it will tend to stall at stop signs, (mainly with automatic transmissions).
For many people, the relearn takes place while coasting down an off-ramp, then the problem of low idle speed mysteriously disappears.
Apr 12, 2019 at 9:38 AM
