Car stalls out upon stopping?
106,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
WAGONBRO33
  • 24 POSTS
Hi all
My car listed above seems to jerk a little when slowing down, almost as if it’s racing to get down into 1st before the car stops, and when it does come to a stop the engine kills. The only way to keep the engine running upon stopping is if I don’t apply the brakes to stop and I just allow the car to very slowly coast to a stop. If it shuts off, I have to start the car back up and allow it to idle for a second before shifting into drive. If I shift it into drive before allowing the car to idle down to normal, the engine will shut off again. Any ideas? TIA
May 26, 2023 at 5:02 AM
  • 110,244 POSTS
Oftentimes, this type of issue is caused by engine vacuum leaks. Have you checked for leaks? If not, start with this.
Here is a link that explains how to locate and repair a leak:
If you are unable to find a leak, scan the computer for codes. This vehicle has an OBD1 system and doesn't require a scan tool to retrieve codes. All you need is a short jumper wire or even a paper clip.
Here is a link that explains how it's done, do this and let me know what you find:
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Let me know what you find.
joe
May 26, 2023 at 4:53 PM
