Engine shut off while driving
150,000 MILES • 2WD • AUTOMATIC
STRANDED505
I was driving and the car stalled. I was able to get it started but it would only continue to run if I feathered the gas. I managed to get home but the car will not run at idle. It does start with a few tries.
Aug 27, 2020 at 8:54 AM
Good evening,
I would first check and see if there are any codes set to help lead us in a direction of failure.
https://www.2carpros.com/articles/stall-at-idle
I would clean the throttle body to be sure there is no carbon build up on the plate. This is a common failure for stalling.
I would also check and see if there is fuel pressure. Low fuel pressure will cause this as well.
https://www.2carpros.com/articles/engine-has-low-power-output
Aug 27, 2020 at 9:17 AM
STRANDED505
Okay, lot of stuff here. Thanks so much for the quick reply. Lets hope I am able to suss out the cause from this info. I'll be back if I have questions.
Aug 27, 2020 at 1:05 PM
Sounds good. We will be here for you if you need us.
Aug 27, 2020 at 8:43 PM
