If I replaced the EVAP canister yesterday and a line fell off of it. Would it cause the car to start then shut off but stay alive while holding the gas? Don’t know why it stays on when holding gas.
SPONSORED LINKS
Friday, April 26th, 2019 AT 2:28 PM
MECHANIC
No, it would not.
I suggested what to check and what you need to check it.
Friday, April 26th, 2019 AT 2:29 PM
ADAMFASCA
MEMBER
Okay problem solved now I added a new throttle position sensor because the code p0122 came on. The car idles correctly but it doesn’t shift. Is there a reset?
Sunday, April 28th, 2019 AT 6:34 AM
MECHANIC
No, there is no reset for the TPS.
Did the transmission shift before the repair of the TPS?
Sunday, April 28th, 2019 AT 6:53 AM
ADAMFASCA
MEMBER
Yes it did and it’s the only code on.
SPONSORED LINKS
Sunday, April 28th, 2019 AT 7:03 AM
MECHANIC
What is the voltage of the TPS at idle?
Also, check it at wide open throttle as well.
Sunday, April 28th, 2019 AT 7:05 AM
ADAMFASCA
MEMBER
I found just now the radiator hose split.
Sunday, April 28th, 2019 AT 7:11 AM
MECHANIC
Okay.
Sunday, April 28th, 2019 AT 7:16 AM
ADAMFASCA
MEMBER
Okay, I fixed the code. My last and final question thanks for all the help car is perfect now. But what would cause the upper radiator hose to start overflowing an trying to spew out?
Sunday, April 28th, 2019 AT 1:42 PM
MECHANIC
It could be just a weak or worn out hose or a failure from too much cooling system pressure.
Sunday, April 28th, 2019 AT 2:04 PM
ADAMFASCA
MEMBER
How many ABS sensor are there. I know one on the rear differential housing is there another?
Sunday, April 28th, 2019 AT 4:52 PM
MECHANIC
3. 2 in the front and the rear one.
SPONSORED LINKS
Sunday, April 28th, 2019 AT 4:55 PM
ADAMFASCA
MEMBER
How do you clean the front one if it’s part of the wheel bearing?
Monday, April 29th, 2019 AT 4:03 PM
MECHANIC
You do not clean it. You replace it.
Monday, April 29th, 2019 AT 4:08 PM
ADAMFASCA
MEMBER
Camaro complete now my 04 Jeep Grand Cherokee 4wd V6 has a engine code p1281
Wednesday, May 1st, 2019 AT 2:50 PM
MECHANIC
I would love to help but site rules are 1 vehicle per question.
You need to go back to the beginning of the site and start a new question. Then I will be glad to help you more.
Wednesday, May 1st, 2019 AT 3:17 PM
ADAMFASCA
MEMBER
Hey man I appreciate all the help first time since 2011 that car has ran and had zero engine light and all systems ready. Thanks.
Thursday, May 2nd, 2019 AT 4:29 AM
MECHANIC
You are welcome.
Always glad to help.
Thursday, May 2nd, 2019 AT 4:46 AM
ADAMFASCA
MEMBER
Camaro I changed the oil pressure switch and oil is spewing everywhere.
