1997 Chevy Camaro idle running high
MIKEJONES97
  • 1997 CHEVROLET CAMARO
  • 6 CYL
  • MANUAL
  • 135,597 MILES
Yesterday I got my car shipped to me from missouri where it has been for the last 8 months and when I got it off the shippers truck I was already expetecing problems. When I started it to drive it into my back yard I noticed the idle was revving up when I took it out of gear. So I changed the oil and air filter and started it up and the idkle seemed fine unitl I moved it and then same problem idle revving when I take it out of gear. This morning I went outside to start it up and thwe idle was running high from the get go and only got higher asd the car warmed up[ what should I do?
Friday, February 19th, 2010 AT 12:13 PM
LEGITIMATE007
  • 5,121 POSTS
I think the gear issue and the idle may be a little coincidental, I would first, clean the throttlebody and throttleplate, of any carbon/debris, then check plugs and wires, and pcv valve, from there egr. Let me know what happens
Friday, February 19th, 2010 AT 12:31 PM
MIKEJONES97
So when I remove the throttle body do I have to replace gaskets or are they re-usable?
Friday, February 19th, 2010 AT 2:44 PM
MIKEJONES97
So when I remove the throttle body do I have to replace the gaskets or are they re-usable?
Friday, February 19th, 2010 AT 2:45 PM
LEGITIMATE007
  • 5,121 POSTS
Yes only if you decide to remove the throttle body, but to clean the plate and the inside, you dont have to do that.
Friday, February 19th, 2010 AT 2:52 PM
