Air idle control valve location
BLACKOP555
  • 10,371 POSTS
Pull the wires off of it and if the temp guage goes to 0 or full red bar then that is not the coolant temperature sensor.
Friday, February 5th, 2021 AT 10:14 AM (Merged)
HIPPYDAWG
  • 1993 FORD EXPLORER
1993 Ford Explorer
where is it located and how to tell if it is bad?
DAVE H
  • 13,384 POSTS
Idle Air Control (IAC) Valve
The IAC valve, mounted on the throttle body, controls idle speed by regulating throttle plate by-pass air. IAC valve includes an air by-pass valve and idle speed control solenoid valve. The air by-pass valve is affected by the engine coolant temperature and functions during cold engine conditions less than 122 °F (50 °C). The idle speed control solenoid is controlled by PCM and works throughout the entire temperature range.
On some models, idle is controlled by idle speed control air by-pass valve. A throttle air by-pass valve is a solenoid-operated valve controlled by PCM. The valve allows air to by-pass throttle plates to control cold engine fast idle, no-touch start, dashpot, overtemperature idle boost and engine load idle correction.
Air by-pass channel carries idle airflow regulated by air by-pass valve. Air by-pass valve is controlled by PCM to adjust both cold and warm idle speeds. Air by-pass valve uses solenoid valve to vary idle airflow volume allowed to enter engine
https://www.2carpros.com/forum/automotive_pictures/266999_iac_1.jpg
Idle Air Control (IAC) Solenoid
Solenoid is by-pass air type. Ensure ignition is off. Disconnect IAC solenoid harness connector. Set DVOM to 200-ohm scale. Measure resistance between IAC solenoid connector terminals. See Fig. 3 . Solenoid has diode. Connect DVOM (+) test lead to terminal VPWR and DVOM (-) lead to terminal IAC.
Resistance should be 6-13 ohms. If resistance is not as specified, replace solenoid. Faults in IAC solenoid or circuit should set a service code. See QUICK TEST in appropriate TESTS W/CODES article in the ENGINE PERFORMANCE Section. If no service code has been set, see CIRCUIT TEST KE in appropriate TESTS W/CODES article for additional testing and specifications.
