Can gas in oil cause engine knock?
212,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
SCRIBBLE1979
Recently I had my S-10 Blazer in the shop and I had them replace the wires, plugs, cap, rotor, fuel injector, fuel pump.
It cost over 1500 dollars.
When I dropped it off, it was running fine. Just doing this for preventative reasons.
When I picked it up, it was misfiring and knocking. I brought it to their attention and they re-gapped the plugs.
Took it home and within driving it for less than 200 miles, it developed a very prominent knock (ONLY ON ACCELERATION, NOT AT IDLE) and upon checking the oil I noticed it was suddenly overfull and smelled like gas. It was also greyish in color.
I took it back to the shop that repaired it and now they say it needs a total engine replacement! Claim its the crankshaft.
The car runs, drives, and does not smoke. It just knocks and not all the time.
Please help me. I fail to understand how 1500 dollars in preventative maintenance turned into a 3000 dollar engine.
I refused to replace it, my Blazer is now in my driveway collecting dust.
Please help.
Jan 28, 2016 at 5:39 AM
fuel in the oil most likely lowered the oil pressure and caused bearing damage.
it sounds like the fuel got there from the injector replacement which I assume is the spider assembly.
Jan 28, 2016 at 6:43 AM
