Camshaft sprockets removal instructions
149,000 MILES • 2.0L • 4 CYL • 2WD
JCLEMO
  • 161 POSTS
I will thank you. .There are a couple things yet. First for future reference.
If you use C clamps to hold the cam gears they work great there is just enough room behind the backing plate
To get the head of the C clamp behind it
And the worm gear you place the. Swivel head on front side of the gear
In between two of the holes and carefully tighten it down. It will not move. took me a while to come up with that plan but it worked. Also I'm concerned about getting the right tension on the belt and leaving the the
Tentioner loose and starting the engine
So it will self adjust concerns me.
What I'm asking is how in the world do you
Tell if it's between . 03-. 33 that's gotta be. A special tool for that?
Jul 1, 2019 at 2:18 AM
Yes. A tension gauge.
Jul 1, 2019 at 2:23 AM
JCLEMO
  • 161 POSTS
Parts store or ?
Jul 1, 2019 at 2:31 AM
JCLEMO
  • 161 POSTS
Can you please send me a diagram of how to tighten power steering belt on the Kia ? No place for adjusting. thanks
Jul 1, 2019 at 3:22 AM
ADJUSTMENT
1. Loosen lock nut.
2. Rotate power steering pump as required to obtain proper tension of drive belt.
3. Tighten lock bolt.
Tighten lock bolt to 30 ft. lbs. (40 Nm).
Jul 1, 2019 at 3:54 AM
