1997 Cadillac STS DTC Codes
DWCBUBBA
I have several DTC codes (1997 STS)
P0404, P0420, P0741, and P1660
How do i trouble shoot these codes and what do I need to do to correct them?
Mar 2, 2007 at 11:57 PM
CHEVY22
  • 1,375 POSTS
hi
p0404 is a generic egr fault , p0420 is twc system low efficiency ,this could be a multiple items , 02 sensors , backed up converter ,p1660 is the cooling fan control circuit this could be firing to the fan or the fan , fan relay or incorrect ground in the pcm ,and the p0741 is the torque converter clutch is stuck off , this will most likely be an overhaul of the transmission , very common , sorry for the bad news
thanks
if you are happy with the info please leave feedback we all here do this for free feedback is a way of saying thank you for the help
Mar 3, 2007 at 5:07 AM
Suggested Repair
Diagnose each code separately: P0404 as an EGR fault; P0420 as low catalytic efficiency, checking oxygen sensors and a restricted converter; P1660 as a cooling-fan control circuit issue involving the fan, wiring, relay, or PCM ground; and P0741 as a torque-converter clutch stuck off, which commonly requires a transmission overhaul.
Conversation Summary
The owner of a 1997 Cadillac STS asked how to troubleshoot and correct codes P0404, P0420, P0741, and P1660. The expert identified P0404 as an EGR fault, P0420 as low catalytic-converter efficiency possibly caused by oxygen sensors or a backed-up converter, P1660 as a cooling-fan control circuit problem involving the fan, wiring, relay, or PCM ground, and P0741 as a torque-converter clutch stuck off that commonly requires transmission overhaul.
