1996 Cadillac SLS turn signal stopped working
CHARLESRJOHNSON1
Electrical problem
1996 Cadillac SLS V8 Front Wheel Drive Automatic
turn signal does not work, but emergency flashers does, fuses are ok
Nov 28, 2009 at 11:23 PM
JDL
  • 16,098 POSTS
Welcome to the forum. Any fuse you check, like the turn fuse, use a testlite on the fuse circuit, if you haven't already, to see if the circuit is hot. It goes hot when you turn on the key. According to my info the turn flasher and hazzard flasher are two different flashers. If everything checks out up to this point, I'd have to check the turn signal switch.
Nov 29, 2009 at 5:57 AM
