2000 Cadillac SLS head lights do not come on automatically,
84,000 MILES • V8 • 4WD • AUTOMATIC
RL1298
My head lights do not come on automatically anymore and last night,I noticed my interior lights dont come on when I hit the botton to unlock the door or when I open the door, The interior lights do come when I hit the map light...??
May 23, 2010 at 8:11 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Maybe the Instrument Panel Integrated Module located behind center dash above radio. Does interior light switch work in overhead consoule?
Thanks for donate
May 25, 2010 at 5:49 AM
RL1298
Be turned on also. But the interior lights do not come on when I open the door and even with the twilight on, the lights do not come on actomatically. The sign on the dash reads Head Lamps suggested! Oh my God I'm driving with out my headlights on..... I was thinking it was a fuse, I could fix it myself?? I know little or nothing about cars.
May 25, 2010 at 10:32 AM
DOCFIXIT
  • 18,828 POSTS
For your and others safety need to have this looked at by Technician. Can headlights be turned on manualy? if no then suggest have this repaired a.s.a.p
May 26, 2010 at 1:35 AM
THUNDER
  • 72 POSTS
what i do with my headlights in my 2000 seville, is set the slide button (underneath the headlight switch) to about the center position and leave the headlight switch in the "OFF" position. Now my headlights come automatically as "safety" lights and automatically switches to driving lights at night or bad weather. As for you "Overhead (or interior) lights make sure your "slide" button is approx. halfway (you'll be able to adjust the brightness) in the middle. this will turn the lights on when you use the remote and automatically turn off approx. 30 sec after you lock the car. hope this helps.
Aug 20, 2010 at 9:29 AM
