1999 Cadillac Seville Warm Hard Start
MPHILLIPS
1999 cadillac seville/SLS.4.7 nothstar engine,94000 miles.when engine is warm car cranks excessive before starting.at times it cranks so much acts like it flooding.I changed plugs and wires,fuel filter,air filter,ran several bottles of fuel injection cleaner in it.There is no codes showing.
Nov 2, 2007 at 1:06 PM
BLACKOP555
  • 10,386 POSTS
try turning the key forward to on and leave 5 secs then turn off repeat that 5 times then try and start. if it starts right up you have a bad fuel pressure regulator or check valve.
any trouble codes?
Nov 2, 2007 at 1:42 PM
Suggested Repair
Cycle the ignition to ON for about 5 seconds, then OFF, and repeat five times before starting. If the engine then starts immediately, the fuel pressure regulator or check valve is not holding pressure and should be checked or replaced.
Conversation Summary
The owner of a 1999 Cadillac Seville SLS with a 4.7 Northstar engine reports excessive cranking when warm, sometimes as if the engine is flooding. Plugs, wires, the fuel filter, the air filter, and fuel-injection cleaner have already been addressed, and no trouble codes are present. The expert recommends priming the fuel system by cycling the key on for five seconds five times; if it then starts right away, a bad fuel pressure regulator or check valve is indicated.
