I have a 1997 STS Seville Northstar V-8 with 75,000 miles on it. It loses over a gallon of antifreeze every day or 2 - no puddles on the ground - no leaks found. When you drive it and maintain speed no more than 55 mph it is fine (until it runs out of antifreeze). If you accelerate to pass or speed up, it immediately overheats but then if you hit the brakes and slow down, it immediately returns to normal temp. Oil is clean. Where is the antifreeze going? Head gasket problem? HELP PLEASE!
Thanks...Laurie
Thanks...Laurie
Oct 17, 2007 at 2:28 PM
