1994 Cadillac Seville Overheating
VICB
Cadi Seville STS 1994, 170k miles 4.6L V8 Northstar. I had a leaky radiator and some overheating problems. I (DIY) replaced the radiator, thermostat, and hoses (upper & Lower). Not overheating now, but my testing showed that temp still reaches 223 F before fans kick in which reduce it to 212 F. This 223 F - 212 temp seems a bit high so I checked engine area and just noticed a small leak coming from original water pump. I think you call it the Weep Hole area (at bottom of WP outer gasket). I suspect a leaky seal in water pump, causing poor engine coolant circulation, allowing temp to rise to 223 F. What do you think, and would it be difficult for me (DIY) to replace water pump? It seems easily accessable, but not sure if any special installation considerations are required. (ie bleeding .....etc.)
I also want to avoid & check for a head gasket leak, but not sure how.
Thanks in advance for your help!
Apr 30, 2007 at 4:50 AM
2CARPRO JACK
  • 11,533 POSTS
That is about the normal temp for the fan to come on. Water pump does take a special socket to remove from the housing, I have seen them at parts stores for relatively cheap if you plan to keep the car, might be a good investment. Have a "chemical test" done on the car, it detects exhaust in the cooling system, not 100%, but what is
May 2, 2007 at 1:27 AM
Suggested Repair
Fan operation near 223 F is about normal. If replacing the water pump, use the special socket available at parts stores. Have a chemical test done to check for exhaust gases in the cooling system; it is helpful but not 100% conclusive.
Conversation Summary
The owner of a 1994 Cadillac Seville STS with 170,000 miles replaced the radiator, thermostat, and hoses after a leak and overheating. Temperature still reaches about 223 F before the fans lower it to 212 F, and a small leak was noticed at the water pump weep hole. They asked about DIY water pump replacement and checking for a head gasket leak. The expert said the fan temperature is about normal, the pump requires a special socket, and a chemical test can detect exhaust in the cooling system though it is not fully conclusive.
