2000 Other Cadillac Models car overheating
2000 CADILLAC
113,000 MILES • V8 • FWD • AUTOMATIC
EDDIECAIN32
i put new waterpump&thermostat on car an it still running hot &seem like coolant not circulating
May 26, 2009 at 2:36 AM
HMAC300
  • 48,601 POSTS
Let your engine gets to operating temp or hot. Then shut off the engine and go under the hood and feel your radiator in several spots. It should be the same temp or feel the same all over. If you feel cold spots or see fins that are loose or corroded, then your radiator is probably bad. Also if that doesn't do anynthing have a pro put apressure tester on it to see if there are any leaks.
Dec 3, 2009 at 3:57 AM
FACTORYJACK
  • 4,159 POSTS
If you are going to spend any more money, have a block test for combustion gases in the cooling system. Head gasket leaks are not uncommon.
Dec 3, 2009 at 2:15 PM
