Escalade will not come out of park
AD831
I have a 2000 cadilla escalde. Sometimes the car does not want to come out of PARK. It seems top hostly happen the hotter it is outside. I was told to play with the ignition, like not turn it all the and see if it comes out of PARK. This seems to help but I still do not know the problem is. Can you please what the problem is and how to fix it
Jul 17, 2006 at 6:41 AM
UNCLEWOOTSIE
  • 40 POSTS
hello i had a simulliar problem, but if you remove the cover off the steering column and remove the brake actuator rod this will allow to to come out of park but go and get a new actuator so the vehicle will remain safe
Aug 14, 2006 at 3:40 AM
PYR0SMURF
check all the fuses, there is a fuse that powers a safety switch that works off the break pedal. It's to keep the car from accidently jumping in gear.
Aug 19, 2006 at 9:05 PM
