Thank you,
Matt
DTC C0286 indicates ABS pressure leakdown. If proper diagnostics confirm a faulty EBCM, replace the unit on the left inner frame rail and clear the ABS codes with a scan tool. Use a repair manual for replacement steps and to determine whether the brakes must be bled.
The owner of a 2002 Cadillac Escalade asked about DTC C0286, EBCM location, how to reset the warning light after replacement, and whether replacement could be avoided. The expert explained that the code indicates ABS pressure leakdown and said to replace the EBCM if diagnostics confirm it. The EBCM is on the left inner frame rail, and a scanner is usually required to clear ABS codes. A replacement tutorial and bleeding guidance were not provided; the owner was directed to the Mitchell repair manuals.
