codes c0205 c0207 c0290?
2002 CADILLAC ESCALADE
108,000 MILES • V8 • 4WD • AUTOMATIC
PLANETARY TRANSMISSIONS
not a lot of information regarding these codes in mitchel on demand. i have to assume like most of gm's electronic issues, that these codes will have a common fix, like a bad body module, or bad steering wheel sensor(s).
Nov 2, 2010 at 1:27 PM
FACTORYJACK
  • CAR REPAIR CONTRIBUTOR
  • 4,159 POSTS
DTC C0205-C0208
Circuit Description
The steering wheel position sensor produces 2 separate voltage signals to indicate steering wheel position to the real time damping (RTD) module. The RTD module converts each signal into a pulse width modulated (PWM) signal to indicate steering wheel position to the EBCM. The EBCM supplies 5 volts to the RTD module on each steering wheel position PWM serial data circuit. The RTD module toggles each of these voltages to ground in order to create the PWM signals. Each PWM signal must have a frequency of 121-134 Hz and a duty cycle of 9-91 percent in order to be a valid steering wheel position signal. With each 360 degree rotation of the steering wheel, each signal transitions from the minimum duty cycle to the maximum duty cycle and then back to the minimum duty cycle. The steering wheel position signals are spaced 90 degrees apart. Therefore, the duty cycles of the 2 signals usually differ, depending on steering wheel position.
Conditions for Running the DTC
C0205, C0206 and C0207
The ignition is ON.
C0208
The vehicle is driven straight forward at a speed greater than 19 km/h (12 mph) for more than 20 seconds.
Conditions for Setting the DTC
C0205
At least one of the steering wheel position PWM signals is out of range for 500 milliseconds.
C0206
The steering wheel position PWM signals indicate a sudden change in the steering wheel position which exceeds a physical limitation.
C0207
The steering wheel position PWM signals do not correlate with each other for 200 milliseconds.
C0208
The steering wheel position that is indicated while driving the vehicle straight forward is at least 20 degrees greater or less than the steering wheel position that was indicated during the sensor initialization period.
Action Taken When the DTC Sets
• The EBCM disables the VSES.
• The message center displays the SERVICE STABILITY SYSTEM message.
Conditions for Clearing the DTC
The conditions for setting the DTC are no longer present and you use the scan tool Clear DTCs function.
Diagnostic Aids
Important: A malfunction between the steering wheel position sensor and the RTD module may be responsible for setting this DTC. When attempting to verify an intermittent malfunction, be sure to use the scan tool to send the Clear DTCs command to the RTD module. This enhances the RTD module's diagnostic capabilities so that the RTD module sets DTCs more readily. Do not cycle the ignition after sending the Clear DTCs command. Test drive the vehicle, making several turning maneuvers in both directions. If the service stability message is displayed due to DTC C0205, C0206, C0207 or C0208, use the scan tool to inspect for Current or History RTD DTCs. If the RTD module has set DTC C0470, C0506, C0521 or C0895, refer to the DTC list in Variable Effort Steering for diagnosis. If the RTD module has set DTC C0550, C0551 or C0870, refer to the DTC list in Real Time Damping for diagnosis.
• Inspect the vehicle for bent, worn or loose steering or suspension components.
• Inspect the vehicle for proper wheel alignment. The vehicle should not pull toward the left or right while driving straight forward on a level surface.
• Use the Snapshot function on the scan tool in order to assist you in locating an intermittent malfunction.
• Thoroughly inspect connections or circuitry that may cause an intermittent malfunction. Refer to Testing for Electrical Intermittents , Testing for Intermittent Conditions and Poor Connections , Wiring Repairs and Connector Repairs in Wiring Systems.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
This step determines if there is a problem between the steering wheel position sensor and the RTD module.
This step tests for voltages supplied to the RTD module from the EBCM. A short to voltage is indicated if voltage on either circuit measures greater than 5.25 volts.
This step tests each steering wheel position PWM signal for a valid Hz frequency. Each measurement is made by backprobing one steering wheel position PWM signal circuit at the RTD module harness connector with one DMM lead and connecting the other DMM lead to a good ground.
This step tests each steering wheel position PWM signal for a valid duty cycle.
The RTD module may be damaged if either of the steering wheel position PWM serial data circuits is shorted to voltage.
Step
Action
Values
Schematic Reference: Antilock Brake System Schematics
1
Did you perform the ABS Diagnostic System Check?
Go to Step 2
Go to Diagnostic System Check - ABS
2
Use a scan tool in order to clear the DTCs.
Start the engine and allow the engine to idle.
Slowly turn the steering wheel back and forth, from lock to lock, several times.
Does the DTC reset?
Go to Step 3
Go to Diagnostic Aids
3
Important: Before proceeding with this diagnostic table, you must determine if a malfunction exists in the steering position signal input to the RTD module. Carefully perform the steps below to determine which diagnostic table you should continue using.
Select RTD/EVO DTC Information on the scan tool.
Important: Perform the action below even if no RTD DTCs are set. Sending the Clear DTCs command to the RTD module enhances the module's diagnostic capability, and allows the RTD module to set DTCs more readily.
Use the scan tool to send the Clear DTCs command to the RTD module.
Select the Display DTCs function on the scan tool to read Current RTD DTCs.
While observing the scan tool, slowly turn the steering wheel back and forth, from lock to lock, several times.
Does the RTD module set DTC C0470, C0506, C0521 or C0895?
Go to Diagnostic Trouble Code (DTC) List in Variable Effort Steering
Go to Step 4
4
Does the RTD module set DTC C0550, C0551, or C0870 during step 3?
Go to Diagnostic Trouble Code (DTC) List in Real Time Damping
Go to Step 5
5
Turn OFF the ignition.
Disconnect from the RTD module, the harness connector containing the steering wheel position PWM serial data circuits. Refer to Electronic Suspension Control Module Replacement in Real Time Damping.
Turn ON the ignition.
Use a DMM in order to measure the voltage between each steering wheel position PWM serial data circuit and a good ground.
Do both voltages measure within the specified range?
4.75 V-5.25 V
Go to Step 7
Go to Step 6
6
Test the suspect steering wheel position PWM serial data circuit for an open, a short to ground or a short to voltage. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 14
Go to Step 9
7
Reconnect the RTD module harness connector.
Use a DMM in order to measure the Hz frequency of each steering wheel position PWM signal by backprobing the RTD module harness connector, one circuit at a time. Refer to Probing Electrical Connectors in Wiring Systems.
Do the frequencies of both steering wheel position signals measure within the specified range?
121-134 Hz
Go to Step 8
Go to Step 11
8
Use the DMM in order to measure the duty cycle of each steering wheel position PWM signal, one at a time.
Do the duty cycles of both steering wheel position signals measure within the specified range?
9-91 %
Go to Step 10
Go to Step 11
9
Inspect for poor connections at the harness connector of the EBCM. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 14
Go to Step 10
10
Important: Following EBCM replacement, use the scan tool to perform the Tire Size Calibration procedure.
Replace the EBCM. Refer to Electronic Brake Control Module Replacement .
Did you complete the replacement?
Go to Step 14
11
Test the suspect steering wheel position PWM serial data circuit for a short to voltage. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 14
Go to Step 12
12
Inspect for poor connections at the harness connector of the RTD module. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 14
Go to Step 13
13
Important: Perform the set up procedure for the RTD module.
Replace the RTD module. Refer to Electronic Suspension Control Module Replacement in Real Time Dampening.
Go to Step 14
14
Use the scan tool in order to clear the DTCs.
Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC reset?
Go to Step 3
System OK
DTC C0290 or C0292
Circuit Description
The powertrain control module (PCM) sends a state of health message to the EBCM within 5.5 seconds after the modules are powered up. This message is sent via serial data communications.
The ignition is ON.
The EBCM fails to receive serial data from the PCM.
If equipped, the following actions may occur:
• The EBCM disables the TCS/VSES.
• The traction off indicator turns ON.
• The message center displays the service stability system message.
Step
Action
Go to Scan Tool Does Not Communicate with Class 2 Device in Data Link Communications
Nov 5, 2010 at 1:02 AM
