2002 Cadillac Escalade Stability Code
LUPCHURCH
Cadillac Escalade AWD 2002, 91K, 6.0L
Yesterday my message center said "Service stability system." I left the car at my local repair garage and received the ECM diagnosis code C0286. When I looked up the code it says "C0286 - ABS Indicator Lamp Circuit Shorted to B+".
Can you tell me what needs to be replaced if anything. My repair garage says it needs $1,100.00 to repair. I need a second opinion.
Thanks for your help.
Feb 9, 2007 at 7:28 AM
CHEVY22
  • 1,375 POSTS
actually the code is mpa switch remins open or closed , the ebcm (electronic brake control module) may have to be replacedas it is internal and the price is in the right range , good luck your shop sounds good
Feb 21, 2007 at 11:30 AM
CD24747
[quote:0cdc4bcb89="lupchurch"]Cadillac Escalade AWD 2002, 91K, 6.0L
Thanks for your help.[/quote:0cdc4bcb89]
I had the same problem and it was a steering wheel sensor. It was $55.00 on ebay and it took me about 10 minutes to put it in. I dont know what my error code was but it was an easy cheap fix. just look under the dash and it is a round white piece around the steering rod. One screw and the rod comes apart and it slides out. Just unplug and slide it off, slide the new one on and plug it in. hope I helped.
Aug 31, 2007 at 4:25 PM
Suggested Repair
The expert interprets C0286 as the MPA switch remaining open or closed and says the fault is internal, so the electronic brake control module (EBCM) may need replacement. The quoted repair cost was considered reasonable. A separate owner reported an inexpensive steering-wheel sensor, but that was not confirmed for this code.
Conversation Summary
A 2002 Cadillac Escalade owner reported a service stability system message and code C0286, which they found listed as an ABS indicator lamp circuit shorted to B+. The shop quoted about $1,100. An expert said the code instead concerns an MPA switch stuck open or closed and that the internal EBCM may need replacement, with the price in the right range. Another owner said a similar symptom was fixed by replacing a steering-wheel sensor, but did not know the code.
